Address locator issue in search result envelope zooming
895
11-07-2012 11:44 PM
shariqueabdul
Hi All
I m getting null exception error in this following code
Private Sub QueryTaskZoomSearch_ExecuteCompleted(ByVal sender As Object, ByVal args As ESRI.ArcGIS.Client.Tasks.QueryEventArgs)
        Dim featureSet1 As FeatureSet = args.FeatureSet
        Dim graphicsLayer As GraphicsLayer = TryCast(MyMap.Layers("MyGraphicsLayer"), GraphicsLayer)
        graphicsLayer.ClearGraphics()
        If featureSet1 IsNot Nothing AndAlso featureSet1.Features.Count > 0 Then
            Dim selectedFeature As Graphic = New Graphic
            selectedFeature = featureSet1.Features(1)
            Select Case featureSet1.GeometryType
                Case GeometryType.Point : selectedFeature.Symbol = DefaultMarkerSymbol
                Case GeometryType.Polygon : selectedFeature.Symbol = DefaultFillSymbol
                Case GeometryType.Polyline : selectedFeature.Symbol = DefaultLineSymbol
                Case GeometryType.Envelope : selectedFeature.Symbol = DefaultMarkerSymbol   // here it shows nothing in envelope
            End Select
            'selectedFeature.Symbol = DefaultFillSymbol
            graphicsLayer.Graphics.Add(selectedFeature)
            ' Zoom to selected feature (define expand percentage)
            Dim selectedFeatureExtent As ESRI.ArcGIS.Client.Geometry.Envelope = selectedFeature.Geometry.Extent
getting error in underline text .... object refernce is not set to an instance of an object
plz help
DominiqueBroux
Esri Frequent Contributor
May be your featureset has only one feature so you should use
selectedFeature = featureSet1.Features(0)
shariqueabdul
Thanx dbroux for prompt reply
i checked with selectedFeature = featureSet1.Features(0) but still same error
plz help
thank you
deleted-user-ATjHIWsdQYmT
Is the selected feature's geometry a point?  if so then the geometry has no extent.  It's just a point.  If it is a point, try using selectedFeature.Geometry.Extent.Expand(10).  You might need to adjust the expand ratio to your liking.
