Adding Text to the legend
2682
9
08-30-2012 12:49 PM
TanyaOwens
I am using the showcase template in API 2.4 (SL4), and I would like to add some additional text to the legend besides just the layers. Is there a way to do this?
-Thanks!
DominiqueBroux
Esri Frequent Contributor
If your need is just to display one label above the legend, why not create a vertical stackpanel with 2 UI elements : the label and the legend?
DavideLimosani
You can use the Refreshed event to modify your legend. Add  Refreshed="Legend_Refreshed" to your xaml and then try someting like this:
       private void Legend_Refreshed(object sender, Legend.RefreshedEventArgs e)
            if (e.LayerItem.LayerItems != null)
                foreach (LayerItemViewModel layerItemVM in e.LayerItem.LayerItems)
                    if (layerItemVM.Label == "myLayer")
                       layerItemVM.Label =  layerItemVM.Label + " additional text";
I think it should work. I didn't try it. And I'm not sure it is the answer to your question, but it may be a starting point
DominiqueBroux
Alternatively to the modification of the label by code, you can also change the MapLayerTemplate and add UIElement binded to any LayerItemViewModel property.
One of the most useful property is the Layer property that allows accessing all layer properties. Example to display layer CopyrightText:
<TextBlock Text="{Binding Layer.CopyrightText} />
For more complex scenario, we can also populate the Tag property by code and include it in the template:
<TextBlock Text="{Binding Tag} />
TanyaOwens
I think I might have not made it very clear what I am looking for. I would like a textblock at the beginning of the legend like:
<TextBlock TextWrapping="Wrap" Text="Select the timeslots you would like to review."/> With the checkbox layers below.
My current legend is modified from the showcase template:
MainPage.xaml:
            <userControls:DraggableWindow IsOpen="True"
                                          x:Name="MapLegendWindow"
                                          Margin="0,27,17,225" Padding="0"
                                          HorizontalContentAlignment="Stretch"
                                          VerticalContentAlignment="Stretch"
                                          Title="Map Legend" Background="{StaticResource BaseColor}"
                                          HorizontalAlignment="Right" Width="205">
                <i:Interaction.Triggers>
                    <i:EventTrigger>
                        <!--<actions:ToggleWindowVisibilityAction />-->
                        <!-- Hide at startup -->
                    </i:EventTrigger>
                </i:Interaction.Triggers>
                <esri:Legend x:Name="Legend" Map="{Binding ElementName=Map}"
                             LayerIDs="AllAvailableFeatureLayer, AMAvailableLayer, PMAvailableLayer, NoneAvailableLayer"
                             LayerItemsMode="Flat"
                             ShowOnlyVisibleLayers="False"
                             Refreshed="Legend_Refreshed"/>
            </userControls:DraggableWindow>
MainPage.xaml.cs:
            LayerItemViewModel removeLayerItemVM = null;
                    if (layerItemVM.IsExpanded)
                        layerItemVM.IsExpanded = true;
                if (removeLayerItemVM != null)
                    e.LayerItem.LayerItems.Remove(removeLayerItemVM);
            else
                e.LayerItem.IsExpanded = true;
                if (e.LayerItem.Label == "AllAvailableFeatureLayer")
                    e.LayerItem.Label = "AM and PM Available";
                if (e.LayerItem.Label == "AMAvailableLayer")
                    e.LayerItem.Label = "Only AM Available";
                if (e.LayerItem.Label == "PMAvailableLayer")
                    e.LayerItem.Label = "Only PM Available";
                if (e.LayerItem.Label == "NoneAvailableLayer")
                    e.LayerItem.Label = "No Times Available";
App.xaml:
        <Style TargetType="esri:Legend">
            <Setter Property="LayerItemsMode" Value="Flat" />
            <Setter Property="LayerTemplate">
                <Setter.Value>
                    <DataTemplate>
                        <StackPanel Orientation="Horizontal">
                            <CheckBox Content="{Binding Label}"
                          IsChecked="{Binding IsEnabled, Mode=TwoWay}"
                          IsEnabled="{Binding IsInScaleRange}" >
                            </CheckBox>
                        </StackPanel>
                    </DataTemplate>
                </Setter.Value>
            </Setter>
            <Setter Property="MapLayerTemplate">
                <Setter.Value>
                    <DataTemplate>
                            </CheckBox>
                        </StackPanel>
                    </DataTemplate>
                </Setter.Value>
            </Setter>
        </Style>
TanyaOwens
If this allows me to add text to the to the beginning of the legend it is clear. When I add textboxes to my current code (see my post # 4 for more info) it doesn't show up.
DominiqueBroux
Sorry I don't see where you added textboxes in your code post#4.
But I you add textboxes in the datatemplate of the LayerTemplate and/or of the MapLayerTemplate, you should for sure see them in the legend next to the checkbox.
TanyaOwens
That is one problem - I want to have the text at the beginning of the legend inside the Draggable Window:
Please select which time slot you would like to display:
Layer one (AM Available)
Layer two (PM Available
Layer three (Weekend Available)
In other words I am using the beginning text to explain how the legend can turn on and off the layers.
DominiqueBroux
TanyaOwens
I am confused on how to do this with the draggable window...
                                          HorizontalAlignment="Right" Width="305">
                    <i:EventTrigger>
                    </i:EventTrigger>
                             LayerIDs="Labels, AllAvailableFeatureLayer, AMAvailableLayer, PMAvailableLayer, WkEndAvailableLayer, CurrentlyUnAvailableLayer, NoneAvailableLayer"
TanyaOwens
Nevermind, I got it: The stackpanal looks a bit different that the draggable window background but it will work I think.
                <StackPanel Background="LightGray">
                </StackPanel>
Now if you could help me with this http://forums.arcgis.com/threads/66163-Feature-DataForm-Need-Help I would greatly appreciate it.
