Add Polygon
3517
12
01-06-2012 11:01 AM
JayKappy
I am using this example to add a polygon: AND it works great
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#EditToolsAutoSave
I am referencing this example to open the data form to edit the data as soon as the feature is added...
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#ToolkitFeatureDataForm
While this works for the Point it is not working for the line and polygon....which require mutliple mouse downs
Is there an event I can place on the Line adn Polygon Feature that when I add a new one i can open the data form
Is there an Editstarted or similar that will allow me to run soem code as soon as I finish creating the feature?
THanks
<esri:FeatureLayer ID="MG_Polygon" Visible="True" MouseLeftButtonUp="Poly_MouseLeftButtonUp"                 Url="http://156.555.555.189/ArcGIS/rest/services/TEST_FS/FeatureServer/24"          DisableClientCaching="True" Mode="OnDemand"         SelectionColor="#FFFFFF00" OutFields="*" />
    Private Sub Poly_MouseLeftButtonUp(ByVal sender As Object, ByVal args As GraphicMouseButtonEventArgs)         Dim featureLayer As FeatureLayer = TryCast(sender, FeatureLayer)          For Each g As Graphic In featureLayer.Graphics             If (g.Selected) Then                 g.UnSelect()             End If         Next          args.Graphic.Select()         MyPolygonFeatureDataForm.GraphicSource = args.Graphic          PolygonDataFormBorder.Visibility = Visibility.Visible     End Sub
Basically just trying to open the data form after the feature is added and allow the user t enter data....the way I hav it above you have to add the feature then click the new feature and then data form opens...for the line and polygon that is....adding a point it opens the data form....
JayKappy
Christopher I hope you are still there....In post #7 you gave an example of changing the Geometry and the featuer layer....
I am trying this and getting errors on the 2nd line....'Geometry' is not a member of 'ESRI.ArcGIS.Client.Editor.Change'
                FeatureDataForm.GraphicSource = change.Geometry
                FeatureDataForm.FeatureLayer = TryCast(change.Layer, FeatureLayer)
                FeatureDataForm.GraphicSource = change.Graphic
JenniferNery
Kindly remove the highlighted line.
ChristopherHill
Sorry,
It was suppose to be change.Graphic I typed change.Geometry by mistake.
