about after using measure behavior, the graph can't stay in the map
12046
24
09-28-2010 12:05 PM
DanDong
I want to ask a question about how to make the polygon stay in the map after using the measure function. I mean I use the measure function to measure the distance of each side of a polygon(measuremode="polygon"), but when I double click the last vertex, the polygon disappear?? I want to keep this polygon. What should I add in the xmal file and cs file? Thank you very much!
SrihariManepalli
This approach worked for me! Thanks
PatrickBrooke
Can you help please, why this decision doesn't work for myMeasureAction.MeasureMode = MeasureAction.Mode.Radius? Procedure Graphics_CollectionChanged is never started...
I am sorry. I have not programmed in Silverlight in over 2 years now and I am afraid that I have forgotten how I solved this issue, I am now working in a 1 man shop so no time to develop any more. Sorry about that. I hope another person who was helped by this can help.
BrandonCales
I haven't figured that out either...but I am working it it again now in 10.1
VenkatRK
Is there any possibility to change the line segment color to any other color instead of "Black"? I have tried to get the full name of the graphic's type and assigning the Text Symbol, created in the xaml, however, I am failed to generate it.
Could anyone please help me out. Actually, I have to change the segment lengths color to "Red" color instead of "Black" with graphics enabled once the measure task is done.
Thanks & Regards,
Venkat
MonaBrisco
This is a very old post but in case some else needs...change color similar manner as this...
                                        <i:Interaction.Triggers>
                                            <i:EventTrigger EventName="Click">
                                                <esri:MeasureAction AreaUnit="SquareFeet" DisplayTotals="True" DistanceUnit="Feet"        MapUnits="Meters"
        TargetName="myMap"
        MeasureMode="Polyline" FillSymbol="{StaticResource defaultFillSymbol}"/>
                                            </i:EventTrigger>
                                        </i:Interaction.Triggers>
   <UserControl.Resources>
        <esri:SimpleFillSymbol x:Key="DefaultFillSymbol" Fill="#33FF0000" BorderBrush="Red" BorderThickness="2" />
   </UserControl.Resources>
