Zoom to specific layer extent
3352
10
06-28-2010 02:11 AM
LukeEvans
I need to be able to zoom to the extent of a specific layer.  Zooming to the initial/full extent of a Map Server isn't a problem.  The issue is trying to get the extent for a specific layer under this.
Here for example.  How would I retrieve the extent values?  The only layer specific information I can seem to retrieve is from a LayerInfo object, which doesn't contain the details I need
Thanks
Luke
RobertScheitlin__GISP
DavideRodomonti1
Hi Luke did u solve this problem?...I have the same too...
David
LukeEvans
Luke,
   You need to use the LayerDetails
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/apiref/com/esri/ags/layers/LayerDetails.ht...
Thanks for your help.  I've got it working now
David
Here's just some little example hacked up code I got going just to test it out
  public function zoomToLayerExtent(layerID:int, layer:ArcGISDynamicMapServiceLayer):void
   var responder:IResponder = new Responder(layerDetailsResult, layerDetailsFault);
   layer.getDetails(layerID,responder);
  public function layerDetailsResult(layerDetails:LayerDetails):void
   // Handle LayerDetails here.  Zoom to layer extent from layerDetails.extent
  public function layerDetailsFault():void
                       // Error code
DavideRodomonti1
                       // Error code
Thanks Luke, it works....but I dont get what I want...
Cause in my code I first apply a layerDefinitions and I want that map.extent is the new layer.extent but I get the original layer extent... :((( :
var dLayer:ArcGISDynamicMapServiceLayer = map.getLayer("Map") as ArcGISDynamicMapServiceLayer;
         var layerDefs:Array = new Array();
         var layerStr:String = new String();
         layerDefs[0] = "c_edificio='" + txtMessage.text + "'";
         layerDefs[1] = "";
         layerDefs[2] = "";
         layerDefs[3] = "";
         dLayer.layerDefinitions = layerDefs;
         dLayer.refresh();
         zoomToLayerExtent(0,dLayer);
David,
   The rest service directory that the LayerDetails is getting the extent info from does not know about any layer definitions that you have applied (as those are client side).
To do what you are trying to do you need to query the map service using your same layer definition query and then get the graphics extent, like this
var graphicsExtent:Extent = GraphicUtil.getGraphicsExtent(featureSet.features);
                        if (graphicsExtent)
                            map.extent = graphicsExtent;
DavideRodomonti1
David,
                        if (graphicsExtent)
Hi Robert, yes u are right I tried with this and it works well!!!
I populated list of value I want to use to make the definition query...but I wish I could use an intelligent text box who show me the values that match in part with what I m writing...
Thank u so much Robert!!
David
David,
   Google "Yahoo Astra"
DavideRodomonti1
David,
Thanks Robert, I saw similar things in a link posted in some discussion of sample flex viewer...now I cant find some sample anymore..
David
David,
   Yahoo's site has several examples. There has only been one or two threads on this in the last year or more and none of them deal exactly with what you are doing.
