Zoom in Scale Range
737
03-14-2012 11:21 PM
NadirHussain
Dear All
  i have question.if i implement zoom visible scale range in mxd document for some layers.this functionality will be shown in rest
service or not.
  if this is not in rest service how can i implement zoom visible scale functionality in flex application for layers.
   Thanks in advance.
RobertScheitlin__GISP
Nadir,
  Yes, once you set a layers min and/or max scale in the MXD and publish  that map the REST endpoint will honor that scale setting. To actually  get a zoom to make layer visible in Flex Viewer you need my TOC widget  as it has that capability.
BTW you should not double post (post in both the Flex VIewer and the Flex API) the same question.
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
IvanBespalov
this functionality will be shown in rest service or not.
Nadir,
HTML && REST
can you see visible scale range?
