WMSLayer: What exactly triggers a WMS GetCapabilities request?
1563
06-15-2011 12:52 PM
YohanBienvenue1
Hey guys,
I'm currently looking into creating a custom WMSLayer component which gives me more control over the specific request parameters I want to set, by extending DynamicMapServiceLayer as seen in this thread: http://forums.esri.com/Thread.asp?c=158&f=2421&t=296210
At the same time I want my custom component to be compatible with the ESRI map component, so that I can use it more or else the same way. So I'm trying to mimic the original WMSLayer properties too.
It's currently working halfway, I can obtain maps from various WMS services if I specify the parameters I want, loadMapData() will properly trigger the GetMap WMS request, but I can't figure out how/where to trigger the GetCapabilities WMS request.
I've already set skipGetCapabilities to false
Do I simply need to manually make the request in my custom WMSLayer constructor?
I believe this needs to happen before the overriden DynamicMapServiceLayer::loadMapData() function is called.
I'd also like to implement the GetFeatureInfo request at some point.
Any hints/tips for me?
Thanks
DasaPaddock
Yes, you can make the request as soon as you like and then call setLoaded(true) when you're ready for loadMapImage() to be called.
