WMSLayer display perfectly in arccatalog and arcmap but in flex
1804
03-02-2011 06:18 AM
DamonSong
    I publish a map service with WMS capability, it displays perfectly when added to arcmap and previews in arccatalog, but shows nothing in flex project using WMSLayer, the arcgis api for flex is 2.2. Any suggestions?
    thanks in advance for any help!
following is my code.
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:esri="http://www.esri.com/2008/ags">
 <fx:Script>
  <![CDATA[
   import com.esri.ags.Units;
 </fx:Script>
 <esri:Map units="{Units.DECIMAL_DEGREES}">
  <esri:WMSLayer
   url="http://sdm:8399/arcgis/services/nef/MapServer/WMSServer"/>
 </esri:Map>
</s:Application>
DasaPaddock
Are you accessing your Flex app at http://sdm:8399/...? If not, you'll need a crossdomain.xml file at http://sdm:8399/crossdomain.xml
See References book at:
http://help.arcgis.com/en/webapi/flex/help/index.html
DamonSong
thanks for your reply!
    i try your suggestion, but it still does not work. My crossdomain.xml is located at "Server10.0\java\manager\web_output\crossdomain.xml", and i can get it at http://sdm:8399/crossdomain.xml
    the screenshots are attached.
DasaPaddock
Can you use a tool like Fiddler or HttpFox to see what requests are being made to your service and what the responses are?
HugoDurana
@xgyb12458
From the code:
I am sorry to point out the possible obvious, but i think you forgot the rest part of the URL e.g:
http://sdm:8399/arcgis/rest/services/nef/MapServer/WMSServer
DasaPaddock
xgyb12458,
You need to specify at least one visible layer.
hugo.durana,
The WMS layer does not use the REST endpoint.
See sample at:
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=WMS
