When Service directory is disabled then not able to query with useamf is true
2643
01-20-2011 08:24 AM
sheebaashraf
when I Disable Services Directory I'm not able to query with useamf true. If I enable the service directory It works for me. I'm using arcgis 10 with SP1
MehulChoksey
Could you also check if its working when you set useamf=false?
sheebaashraf
When useamf = false then it works irrespective of service directory is enabled or disabled
