What is FeatureLayer selection for?
1313
11-09-2010 02:44 PM
DavidElies
I'm trying to use the FeatureLayer.selectedFeatures to run a query, but I don't know how to get the geometry.  So, my questions are multiple:
What are the selectedFeatures supposed to be used for anyway?
Can I get the geometry from selected features?
Is there a way to get the geometry from multiple polygons?
Thanks so much!
DasaPaddock
It's usually used in editing scenarios. You first have to select the features using:
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/FeatureLayer.html#selectFeatures()
DavidElies
Thanks for the reply, dpaddock!
Because of the simplicity of selecting, I thought it would be the answer to my dillema, but perhaps it isn't.  Is it possible to get the union of Polygons?  It looks like there is a union function for Extents, but since it returns an Extent, I assume it just returns the bounding box that contains both Extents, (which would include a lot more area than I want).  I was really hoping to use the geometry of disconnected polys in a query.  Is this even possible?
DasaPaddock
DavidElies
Thanks dpaddock!
I didn't realize that polygons naturally supported multiple disjoint shapes.  I didn't understand what the rings were.  I added each ring from my selected polygons to a "master" polygon and used that as the geometry for the query!  This is exactly what I was looking for.  Thanks so much!
