Web Editing Layers Sometimes Don't Show
914
02-03-2012 04:20 AM
StuartBlumberg
I have created a web editing application using the FlexViewer.  In the mornings when I open the application, in the editing window it says there are no editing features available (or something like that) or only the point markers are available and not the polygon markers.  I refresh the application and everything works normally.  It seems as though the service is timing out and needs to be "awakened."  During the day, if I leave the application for a time it will happen again.  Is there a setting I need to change to prevent this from happening again?  Thank you!
RuiShen
I am not sure whether this gonna help.
But you could try to clear your server rest caches.
You can refer to this blog below:
http://blogs.esri.com/Dev/blogs/arcgisserver/archive/2010/10/08/Clearing-the-ArcGIS-Services-Directo...
StuartBlumberg
Yes, I've tried this but did not fix the issue, thanks.
