<?xml version="1.0" encoding="utf-8"?> <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" xmlns:esri="http://www.esri.com/2008/ags"> <mx:Script> <![CDATA[ import com.esri.ags.layers.LOD; private function addLODs():void { var lods:Array = myMap.lods; lods.push( new LOD( NaN, 0.00000713838288433451, 3000) ); lods.push( new LOD( NaN, 0.00000356919144216726, 1500) ); lods.push( new LOD( NaN, 0.00000118973048072242, 500) ); // About NaN: sorts based on scale, so setting level isn't needed myMap.lods = lods; } ]]> </mx:Script> <mx:Text fontSize="11" width="100%" text="Zoom in past 1:4,500 and you'll notice the basemap switching. When zoomed out, ArcGIS Online Street Map is used, but when zoomed in a dynamic service for Louisville, KY will display parcels, landuse, and planning." /> <esri:Map load="addLODs()" id="myMap"> <esri:extent> <esri:Extent xmin="-85.804" ymin="38.270" xmax="-85.797" ymax="38.275"/> </esri:extent> <esri:ArcGISTiledMapServiceLayer visible="{myMap.scale > 4500}" url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/> <esri:ArcGISDynamicMapServiceLayer visible="{myMap.scale < 4500}" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/M..."/>
</esri:Map> </mx:Application>
the code under visible="{myMap.scale < 4500}" shows error when I am using in <esri:ArcGISDynamicMapServiceLayer/> even I have replace the < symbol by < but again same problem persist plz....give a solution my email id is [email protected]
