VerifyError: Error #1014: Class mx.controls::DataGrid could not be found.
1199
11-30-2011 02:13 PM
RichardTalton
I'm using Flash Builder 4.6 & the ArcGIS Flex API 2.4
When trying to use the InfoSymbol, I get this error:
VerifyError: Error #1014: Class mx.controls DataGrid could not be found.
I think the InfoSymbol is at fault and may be using outdated MX components. Is there a way of seeing the source of the infoSymbol?
Also, what other component can be used instead of the infoSymbol to get the same results as the InfoRendererWithStates component example?
RichardTalton
