Using the pop ups with Rasters in a feature dataset
2315
11
06-21-2011 04:03 PM
JoshJones1
I have a feature class with a separate raster image within a raster data column associated with each record of the feature class.  I am trying to use the popup widget to have it contain the image that is within each record so as a different image will be pulled when each point is clicked upon.
Is this possible to do this, or does anyone know another way that I would be able to have the popup widget pull a separate image file for each of the points within my map?  I don't mind having them pull from a separate location but I need it to be able to pull a different image for each point.
Any help would be appreciated.
Josh Jones
JoshJones1
Robert,
I opened the main and popup config files directly in IE and there seem to be no errors present as those that show up when a direct error is provided (such as #1085 when I enter my code incorrectly).
I began with a new main config file and I then grabbed a brand new main config file from a new flexviewer file I just downloaded. I added just the sculpture layer and it worked, but as soon as I add the popup sublayer the "Application Error" again comes onto the screen and the popup window doesn't work.
I'm not sure what else to try.
Thanks Robert.
-Josh
JoshJones1
Robert,
I found an error in my PopUp config and now it's working.  Thanks for the help.  Do you know if it is possible to center the images once they are in the PopUp window.
Thanks again.
-Josh
