Using projection for visualization in Arcgis.com and Explorer on line with API Flex
1448
06-30-2011 12:32 PM
hervéparmentier
I'm a new user of Arcgis serveur, and i 'm trying a simple map service with vector data.
First i try to publish using API REST service in Arcgis directory with :
- Arcgis explorer on line : i can see my map but without base map, and i don't now what to do for adding it. I can verify the coordinate projection
- ARCGIS.com :  i can see my map... but near Lagos in Nigeria, and the map talk about the Drome river, in France.
I try french Lambert 93 projection coming from Arcgis desktop listing and the WGS 84 projection but the same result
Do you have a idea please to help me.....
Thank by avance
HPa
BjornSvensson
Esri Alum
HP,
I'm not sure I understand 100%, but I think the question you are asking is "why does my map service of France show up in Nigeria?".  Here are a few things that might clarify it for people trying to assist you 🙂
Q1. When you published your service, can you go the Service Directory page for that service?
The Service Directory page will usually be:
http://yourserver/ArcGIS/rest (if you are using ArcGIS Server .NET)
For example:
http://maps.esrifrance.fr/ArcGIS/rest/services/demo_FFR/MapServer
Q2. What projection does it say your Map Service is in?
For example, the Map Service above has:
"Spatial Reference: 2154"
Q3. Is the map cached or not?
"Single Fused Map Cache: false" - means that the map is not cached.  If it's "true", then the map is cached.
Q4. If you click the "View In ... ArcGIS JavaScript" - does it work? What happens?
Q5. If you click the "View In ... ArcGIS.com Map" - does it work? What happens?
Q6. Is the service available to the public (so that we can see it directly)?
If your ArcGIS Server is on an internal network - is it a secured service?
hervéparmentier
Hi Bjorn,
thank you for your answer.
The problem is like you said : "why does my map service of France show up in Nigeria?"
That is my answer of your 5 questions :
I just use it to pick up the URL of the Rest services
That's a french projection in Wkt comming from the library projection of arcgis desktop V.10 , but i haven't any Wk ID like EPSG code b  : RGF93 / Lambert-93   Code: EPSG::2154   Type: ProjectedCRS   Status: Valid   Domain: France - onshore and offshore, mainland and Corsica.    (source: http://spatialreference.org/ref/) .
May i modify the parameters ?
That's my result of projection :
PROJCS["WGS84",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",700000.0],PARAMETER["False_Northing",6600000.0],PARAMETER["Central_Meridian",3.0],PARAMETER["Standard_Parallel_1",44.0],PARAMETER["Standard_Parallel_2",49.0],PARAMETER["Latitude_Of_Origin",46.5],UNIT["Meter",1.0]]
Q3.  There is no map cache it's a feature service in first test.
i can see my map will all the layers.
ArcGIS.com Map", i ses my map service near Lagos.
And for arcgis explorer on line, I see y map without base map.
Arcgis is developed on internal network, like an intranet network. It is a secure service.
Q5.
hervéparmentier
Hi Bjorn,
For precision i have in Arcgis Explorer on line my map to this WGS 84 coordinates :
7°34'54''N and 3°54'33" E
Thank you by advance,
Hervé Parmentier
