TOC groups in Accordion, FlexViewer 2.1
2743
10
10-29-2010 12:23 AM
MattiasEkström
Hi!
I would like to group my services in the TOC in several groups in an Accordion, like this TOC http://resources.esri.com/arcgisserver/apis/flex/index.cfm?fa=codeGalleryDetails&scriptID=15874 from the old code gallery (the groups version of it).
Has anyone done this or something similar in the FlexViewer 2.1?
I'm also thankful if someone could point me in the right direction and give me some tips on where to begin.
RobertScheitlin__GISP
Mattias,
   Yep I created a copyright widget a little while ago.
http://www.arcgis.com/home/item.html?id=3893f396489344aa9f8fcdef15b3fe1b
Don't forget to rate and comment on the widgets you use form the code gallery.
Mattias,
   Here it is for FlexViewer2.1
MattiasEkström
Thank you so much Robert!
That's great! I could even implement the code in the MapSwitcherWidget, so it works exactly as I want.
ionarawilson1
Mattias,
Hi Robert,
Is there any way I can use this in my Flex Application? (I am not using Flex Viewer)! It seems like a great tool but I cant use the widget since I am not using Flex Viewer or can I?
Thank you!
Ionara,
   You are correct it would take a MAJOR re-write to decouple it from the Flex Viewer.
MattGiles
Hi Robert,
I am using your accordian TOC widget as a workaround for the lack of layer grouping functionality in the existing viewer TOC. It works great except the LayerMenus (move up, move down, transparency, description etc) do not work - can you provide me with some direction as to how i could get these working? I've tried poking around but the TOC involves fairly complicated code..
Thanks so much!
MattGiles
Got it - just needed to put TOCAccordion in com.esri.viewer.components.toc package so that i could reference TOC through: [xmlns:TOC="com.esri.viewer.components.toc.*"].
MattGiles
Fantastic widget Robert - may i ask why you don't share this on the code gallery?
M Giles,
    If you hadn't noticed I have enough code in the code gallery to maintain. Most people are fine with the TOC I provide, there is just a handful that need to group things in the TOC.
