Thematic Map Widget (ThematicQuery)
1278
02-13-2011 08:18 PM
RashidMalik1
Hello all,
I am kind of new to Flex development and have a question someone might be able to answer fairly quickly.  Basically, I want a slight widget code tweak to do the following:
A sample is located at the following link for reference:
http://help.arcgis.com/en/webapps/flexviewer/live/index.html?config=config-thematic.xml
I want all themes to be selectable via a drop-down menu as opposed to clicking on the radio button.  If you are trying to display several themese in one application, the list can get long.  What would be great also if there is a way to organize themes by type.  This is just a wishlist but I would greatly appreciate if someone can assist me with the first request.  I would greatly appreciate a compiled version if possible as I am in the process of getting the Flash Builder software.  Thanks in advance.  Rashid
veselinivanov
Hi, I want to create a Thematic Map in a silverlight app. This simple on flex is very well. Have you got any simples on a silverlight or source code?
MehulChoksey
whitesnake,
For Silverlight related questions, you will get more revelant responses from  forum:
http://forums.arcgis.com/forums/19-ArcGIS-API-for-Microsoft-Silverlight-WPF
veselinivanov
�?к, I understand.
Thank you Mehul
