TextSymbol with embedded font not working
2850
10-25-2010 07:46 PM
MikeMcDougall
I have an embedded true type font that I have successfully displayed through a label on a widget within the viewer:
          <s:Label id="SymbolLabel" fontFamily="ERSIncidents" fontSize="45" text="A">
However when I try to use that same font in a TextSymbol it does not work. Just the plain letter A displays on the map instead of the font symbol.
var pictureGraphic:Graphic = new Graphic();
var symbol:TextSymbol = new TextSymbol();
symbol.text = "A";
var textFormat:TextFormat = new TextFormat();
textFormat.font = "ERSIncidents";
textFormat.size = 60;
symbol.textFormat = textFormat;
pictureGraphic.geometry=this.convertLatLonToMapPoint(incident.lon, incident.lat);
pictureGraphic.symbol= symbol;
mapLayer.add(pictureGraphic);
Any ideas? Is there some difference in font versus fontFamily?
Mike
RobertScheitlin__GISP
Mike,
  I remember going through this before and what you have to did (if I recall correctly) is add the embeded font to the index.mxml.
Ganael_Jatteau
Hi, I have the same problem with a font that is not in the client side but embedded into a SWF.
The font is embedded like this in the SWF named  fonts_container.swf:
[Embed(source="/assets/esri_150.ttf", fontFamily="ESRI AMFM Electric", embedAsCFF="true")]
private var ESRI_AMFM_Electric:Class;
public function fonts_container()
      Font.registerFont(ESRI_AMFM_Electric);
and i call it in my application (application.swf) like this :
@font-face {
   src:url("assets/fonts_container.swf");
   fontFamily: "ESRI AMFM Electric";
And this symbol is not displayed correctly :
<flash:TextFormat id="ftf" font="ESRI AMFM Electric"/>
<esri:symbol>
<esri:TextSymbol id="txt1" text="S" textFormat="{ftf}"/>
</esri:symbol>
If I add the font in the client device and remove the @font-face, the symbol display correctly.
It is a problem because the font is not supposed to be installed on the client device.
Am I forgetting some parameters to make the  symbol display correctly with embedded font ?
DasaPaddock
Which versions of the Flex SDK and ArcGIS API for Flex are you using?
