Strange behaviour in layers involved in Editing
1069
09-13-2011 02:33 AM
BharathiChandran
Hi all,
I had just created a Basic application and wanted to add the Edit functionality. When I configured the Edit Widget then two unexpected things happen:
1. The operational layers defined in config.xml (type = "feature") for editing once added, in the initial screen it does not fit appropriately onto the base map (looks skewed). However once the fit to extent button is clicked, everything falls into place.
2. I have configured 4 layers for editing. Although all the four layers show up in the widget, 3 of them work fine. The fourth one when attempted with edits throws up an error - "Add feature failed". Also only on this layer is the symbology different from what is defined in the mxd of the map service. The symbology defined is a simple fill symbol for that polygon layer. And there is a template defined in mxd.
Any clues/ leads appreciated.
Bharathi
BharathiChandran
Hi..
I am still facing the first issue although the second issue i had fixed (by restarting the map service and clearing the cache). Wonder if someone else is facing similar issues. Had just posted the screenshots just to show the problem clearly.
Would be grateful for any help / leads.
Bharathi
