Sort Unique Values in Ascending Order using Query Builder
3269
05-17-2010 08:17 AM
JasonHancheruk
I am trying to return only unique values and then sort them in ascending order using Query Builder for SFV1 1.3. I have tried to adapt some codes that were published in the old forums, but nothing has worked. Has anybody implemented this in there own project? Any help would be appreciated.
/*  private function onFieldValuesRereivalsuccess(obj:Object):void{
   mqbMessage = "Values has been retreived."
   CursorManager.removeBusyCursor();
   var fset:FeatureSet = obj as FeatureSet;
   mqbMessage = "";
   mFldValues = fset.features;
   mqbMessage = "Values have been retreived."
   mqbMessage = "";
//use the uniquearray function to get a unique list.
   mFldValues = uniqueArray(fset.features);
  private function uniqueArray(a:Array) : Array
      var unique : Array = new Array();
      var contains : Boolean;
       for( var i:Number = 0; i<a.length; i++ )
            contains = false;
            for (var j:Number = 0; j<unique.length; j++)
                if (a == unique) contains = true;
            if (!contains)
        if (a != "")
            unique.push(a);
      return unique;
Jason
CristianJonhson
I dont know if I understood what u were asking for, but maybe it is something like that?
  private function sortArrayRemoveDupl(arr:Array):Array
    var newArr:Array=[];
    var pivo:Object=arr.shift();
    arr.sort();
    newArr.push(pivo);
    while (pivo!=null)
     if (pivo == arr[0])
      pivo = arr.shift();
     else{newArr.push(pivo); pivo = arr.shift(); }
    newArr.sort();
    return newArr;
This should set a new array with unique values and order it... but remember, if u give a featureSet to sort and remove duplicated, it will compare FULL objects, not only the field u want, to do a sort on a field from a table, u should use feature.attributes.ATRIBUTE.
Att.,
Cristiano Benato
SusanMordy1
Barbara's code posted here: http://forums.esri.com/Thread.asp?c=158&f=2421&t=302204
Will return unique values.
You just need to add:
private var mFldValues2:Array = null;
to QueryBuilderWidget.mxml  in addition to the code provided by Barbara.
Not ascending, but it's a step in the right direction.
JasonHancheruk
Sorry I did not reply sooner, but I thought these threads would send an email as the older forums did. Guess I need to check my settings.
The action script I used was incorporated from Mark Hoyland in the forum, http://forums.esri.com/Thread.asp?c=158&f=2421&t=302204, as the one from Barbara Patterson caused 14 errors of "1013: The private attribute may be used only on class definitions" through the rest of the private functions in the QueryBuilderWidget.mxml.
Not sure how to fix this error?
Jason
NathanEnge
   mqbMessage = "Values have been retrieved."
   mqbMessage = "";
   //First array that contains all the features
   mFldValues2 = fset.features;
   //The name of the field the user has selected
   var fldname:String = fieldsLst.selectedItem.Name
   //The new array that will contain only unique features based on the selected field
   mFldValues = new Array();
   for( var i:Number = 0; i<mFldValues2.length; i++ ) {
            contains = false;
            for (var j:Number = 0; j<mFldValues.length; j++)
              // Lines below return the string value for the selected fields from the 2 arrays
               var item1:String = mFldValues2.attributes[fieldsLst.selectedItem.Name];
               var item2:String = mFldValues.attributes[fieldsLst.selectedItem.Name];
               if (item1 == item2) contains = true;
          //if the value is not already in the array add it to the array
            if (!contains)
                 mFldValues.push(mFldValues2);
      var myArray:Array = new Array();
      var strValue:String = "";
      for (var a:Number = 0; a<mFldValues.length; a++)
       strValue = mFldValues.attributes[fieldsLst.selectedItem.Name].toString();
       myArray.push(strValue);
       //Alert.s...
