Show Metadata of Layer
1221
11-01-2010 08:52 PM
shafitrumboo
Hi
I have to show metadata of the layer. I tried the sample of Robert Scheitlin.
I found sde.GDB_UserMetadata table doesn't exits in (Arcgis 10/ Latest version of Arc sde)
I found table "GDB_ITEMS" that contains the information. but the XSLT present in the sample doesn't parse them
RobertScheitlin__GISP
Shafi,
   They have so completely reworked how metadata is done in ArcGIS 10 that the old code will not work at all even if you do get it pointed to the right data. I am really confused about metadata in 10 and am not sure I will be coming out with a solution to this for 10.
