SFV 1.3 Query builder Widget - Date field - underlying DBMS
3409
06-17-2010 08:52 AM
SusanMordy1
Does anyone know what needs to be modified in the query builder widget code to work with Oracle SDE date fields in my map service?
The query Builder widget does not know what the DBMS management system is.  What is entered into the filter box is passed to the server as a request.  The server then passes that string to the DBMB and therefore needs to match the syntax requirements of the DBMS.
When a user double clicks an esriFieldTypeDate field in my map service, I need code that creates the date syntax that the esriFieldTypeDate field (Orcale SDE) in my map service requires.
Thanks for your help,
Susan
DouglasGuess
Try this...
TO_CHAR(<your date field name>, 'MM/DD/YYYY')
SusanMordy1
Hi Doug,
Sorry, I am not sure how I would incorporate the above code into Querybuilderwidget.mxml..
