setting full extent in "straight" API application
985
03-17-2011 01:12 PM
JustinRiggs
in the sample viewer there's a fullextent property that you can set to constrain the map's full extent. Can you do this same thing in a "straight" API application? If so, would someone mind sharing the syntax?
andrewj_ca
When you load your page set a fullExtent variable:
private var fullExtent:Extent = new Extent(x,y,xx,yy,map.spatialReference);
Then create a function to use that when you want thje full extent shown.
Mine looks like this:
private function mapfullExtent():void
try{
  if (fullExtent !=null)
   map.extent = fullExtent;
  }else{
   navToolbar.zoomToFullExtent();
}catch(err:Error){
KenBuja
MVP Esteemed Contributor
Take a look at Mansour Raad's blog on constraining the extent
