Set timelimit and time out in Flex Compiler
1295
07-06-2011 12:58 PM
francescodi_vito
Hy guys
i have a GP Service that takes more time to run. And so i must set i time limit or timeout in flex compiler
i wrote this in flex compiler
Additional Compiler Argument:
-locale en_US -source-path=locale/{locale} -keep-all-type-selectors=true -default-script-limits 5000 6000
but when i run my gp i Flex Viewer App. i have always the error that ShackWave Flash not respond
what i do to set the time out of Flex Viewer App.? or i have to set a time out for the widget that call the GP Service?
Help please
BjornSvensson
Esri Alum
Is your GP task running as "Synchronous" or "Asynchronous"?
Asynchronous execution is better for slower running GP tasks.
From the documentation:
In synchronous execution, the client executes the task and waits for a response before proceeding. The Supported Operations section of the Services Directory displays "Execute Task" for synchronous tasks.
In asynchronous execution, the client submits a job, then verifies that it was successful using a unique job ID. When the task completes, the client can retrieve the results. The Supported Operations section of the Services Directory displays "Submit Job" for asynchronous tasks.
http://help.arcgis.com/en/webapi/flex/help/index.html#/Geoprocessing_tasks/017p00000003000000/
francescodi_vito
hi bjorn
my GP Service is Synchronous and this is the script that i wrote for call him in FlexViewer
<fx:Script>
  <![CDATA[
   import com.esri.ags.FeatureSet;
   import com.esri.ags.Graphic;
   import com.esri.ags.SpatialReference;
   import com.esri.ags.events.GeoprocessorEvent;
   import com.esri.ags.events.GraphicsLayerEvent;
   import com.esri.ags.events.MapMouseEvent;
   import com.esri.ags.geometry.Geometry;
   import com.esri.ags.symbols.SimpleFillSymbol;
   import com.esri.ags.symbols.SimpleLineSymbol;
   import com.esri.ags.symbols.SimpleMarkerSymbol;
   import com.esri.ags.tasks.Geoprocessor;
   import mx.controls.Alert;
   import mx.rpc.events.FaultEvent;
   private function startGeoProcess(event:MouseEvent):void
    var parms:Object = new Object();
    parms.Condizione = String(condizione.text);
    parms.Valore = Number(valore.text);
    var geoprocessTask:Geoprocessor = new Geoprocessor();
    geoprocessTask.outSpatialReference = map.spatialReference;
    geoprocessTask.showBusyCursor = true;
    geoprocessTask.url = "http://193.204.163.134/ArcGIS/rest/services/Peso_di_Volume_Medio/GPServer/PesodiVolumeMedio";
    geoprocessTask.useAMF = false;
    geoprocessTask.execute(parms);
    geoprocessTask.addEventListener(GeoprocessorEvent.EXECUTE_COMPLETE, executeCompleteHandler);
    geoprocessTask.addEventListener(FaultEvent.FAULT, faultHandler);
   private function executeCompleteHandler(event:GeoprocessorEvent):void
    var myPointSymbol:SimpleMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10, 0x1AA1D3, 0.2);
    for each (var graphic:Graphic in event.executeResult.results[0].value.features)
     graphic.symbol = myPointSymbol;
     graphicsLayer.add(graphic);
     map.addLayer(graphicsLayer);
   private function faultHandler(event:FaultEvent):void
    if (event.type == "fault"
     && event.fault.name == 'Error'
     && event.fault.faultCode == '500'
     && event.fault.faultString == 'Error Executing Task')
     Alert.show("Oops - no results.  Try clicking in an ocean...");
    else
     Alert.show("Unexpected fault:\n" + event.toString());
 </fx:Script>
And it's ok if the model responds immediately.
I tried to write this code for Asynchronus property. And i changed the script with
geoprocessTask.submitJob(parms);
and
geoprocessTask.addEventListener(GeoprocessorEvent.JOB_COMPLETE, executeCompleteHandler);
But in this way the widget don't give me a graphic response.
Why Bjorn? Where is the error?
Please Help me
francescodi_vito
What do you think Bjorn?
