Selecting by polygon
3733
11
08-25-2010 08:04 AM
RichardKrell
I am tearing my hair out over something that I am sure is a simple thing but I have been looking at for so long I am not seeing the obvious so any help would be greatly appriciated.
I started by looking at the code provided at http://resources.esri.com/arcgisserver/apis/flex/index.cfm?fa=codeGalleryDetails&scriptID=15872
Then I took pieces of it to create my own using my services.  I have attached the mxml file named testshape.txt.  I am also including a output of what happens after I draw the polygon and it is called output.txt.
It appears it is finding the records in the polygon and then I think it is creating the graphics element but that is where it is blowing up.  Please take a look and advise please.
RichardKrell
My fault... I have 2 services, one that is real production and then my test service.  I had restarted the wrong service.  IT ALL WORKS NOW.  Thanks a lot Andrew.  That is several days work and stumbling done thanks to you.
by Anonymous User
Not applicable
Original User: cgishack
No problem... You will never turn off the SHAPE field ever again 🙂
Drew
