select and zoom to a feature works for polygon feature, but for polyline only zoom not select
3871
12-07-2014 07:23 PM
LiYao
Hello everybody,
I have 2 layers in the map (1 polyline layer and 1 polygon layer), and a "select and zoom" function which will select a feature and zoom to it.
The strange thing is although I use the same code(except the geometry type), the result is different:
- for polygon feature : can select the feature and zoom to it properly.
- for polyline feature : only zoom to the feature, but never select the feature.
I cannot figure out why this happen, is this because of the layer data or something else?
The code I am using is as follows:
private function onSelectItem(e:ContextMenuEvent):void{
    if(datagrid.selectedIndex >= 0){
     this.cursorManager.setBusyCursor();
     if (datagrid.selectedItem.shape == "Polyline")
      var query:Query = new Query;
      queryTask.url = "http://localhost:6080/arcgis/rest/services/MyService/MapServer/0";
      query.where = "Segment_ID = '" + datagrid.selectedItem.segmentID + "'";
      query.outSpatialReference = map.spatialReference;
      query.returnGeometry=true;
     queryTask.execute(query, new AsyncResponder(onResult, onFault));
     else if (datagrid.selectedItem.shape == "Polygon")
      var queryP:Query = new Query;
      queryTask.url = "http://localhost:6080/arcgis/rest/services/MyService/MapServer/1";
      queryP.where = "Segment_ID = '" + datagrid.selectedItem.segmentID + "'";
      queryP.outSpatialReference = map.spatialReference;
      queryP.returnGeometry=true;
      queryTask.execute(queryP, new AsyncResponder(onResultPolygon, onFault));
     function onResult(featureSet:FeatureSet, token:Object = null):void
      graphicsLayer.clear();
      if (featureSet.features.length == 0)
       Alert.show("No feature found. Please try again.");
      else
       var unionExtent:Extent;
       var myFirstGraphic:Graphic = featureSet.features[0];
       unionExtent = Polyline(myFirstGraphic.geometry).extent;
       myFirstGraphic = new Graphic();
       for each (var myGraphic1:Graphic in featureSet.features)
        myFirstGraphic.geometry = myGraphic1.geometry;
        graphicsLayer.add(myGraphic1);
        if(myGraphic1.geometry !== myFirstGraphic.geometry){
         unionExtent = unionExtent.union(Polyline(myGraphic1.geometry).extent);
       map.extent = unionExtent;
     function onResultPolygon(featureSet:FeatureSet, token:Object = null):void
      else
       unionExtent = Polygon(myFirstGraphic.geometry).extent;
         unionExtent = unionExtent.union(Polygon(myGraphic1.geometry).extent);
     function onFault(info:Object, token:Object = null):void
      Alert.show(info.toString());
I am using ArcGIS api for flex 3.6, thanks in advance.
