Security sandbox violations
1125
05-27-2011 10:40 AM
JohnGarvey
I am using a web proxy (varnish on linux) in front of arc server (on IIS). Sometimes, my dynamic map service layers come through fine and other times they throw a security sandbox error.
I have a crossdomain.xml file in the web root of the IIS and can see the file when navigating through the proxy.
I am not too sure where to start. Is this a time-out error or should I move or edit  the crossdomain file? Right now it is wide-open to all domains.
any help would be great.
DidumAbraham
Does the URL of your flex application when deployed out begin with a "http://"?
JohnGarvey
Sorry for the delay.
Yes, I am using http.
-john
DidumAbraham
I'm not sure how to go about with this error but normally I handle it by inserting http://... One other suggestion would be to check your virtual directory set up.
