Search Widget Select by Point
2881
04-12-2010 09:36 AM
JayGeisen
Is there some way to make the Select by Point function of the Search Widget recognize point data?  Currently, if I try to use the Select by Point button to select a point object, nothing happens.  Is it a matter of a tolerance set too low maybe?  Any help is appreciated.  Also, I am using Rsheitlin's Enhanced SearchWidget with Floating Datagrid, if that makes any difference.  Thanks
RobertScheitlin__GISP
jgeisen,
    There is not a search tolerance for the searchwidget when using the point option, but here is a link where I show how to add that type of capability in Action script.
http://forums.esri.com/Thread.asp?c=158&f=2421&t=295461&mc=2#921934
JayGeisen
Thanks Robert.  I will give this a try.
JayGeisen
Robert, that fixed it!  Now, is there any way to apply that same tolerance for the Select by Rectangle (Extent) when one uses that tool and simply clicks in one spot?
