Scale barissue
2640
01-29-2012 09:40 PM
shafitrumboo
Dear All,
I'm using Arcgis flex APIS  but Am struggling with scale bar. We stared the application with flex api's 2.0 the scale bar was showing correct but once we migrated to 2.4 it displays null instead of  units and in 2.5 it shows no value
Please find the attached screen shot for as out put. PLease be noted am using same map services
shafitrumboo
I did some R&d  Here are the details:
1. I create one poc using same map service and found it's working with flex 2.4 and 2.5 both.
2. I'm Load localization resources at runtime using XML and flex object XMLResourceLoader. that created a problem although i don't translate the units.
Can anyone give me a lead
by Anonymous User
Not applicable
Original User: rscheitlin
Shafi,
   You have encountered the bug in 2.5 API reported here:
http://forums.arcgis.com/threads/47052-Localization-breaks-scale-bar-in-2.5?p=161059&viewfull=1#post...
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
