resourcemanager french fr_FR not working
1428
01-12-2012 05:43 AM
DebbieAlger
Me again on languages issues.
I now want to see the default French show on the page but I get errors when trying to use French ie.
-locale en_US,fr_FR
error ->   "unable to open 'locale/fr_FR'"
this folder exists on the sdk/frameworks folder.
After this,  I should be golden!
thanks
DasaPaddock
Use:
-locale=en_US,fr_FR
DasaPaddock
Are you creating your own bundle too or just trying to switch between the locales on the SDK bundles?
If you're creating your own, does it also exist in your projects own locale/fr_FR folder?
DebbieAlger
yes, I am creating my own, and it does exist on my project folder. It only has 1 value so far for testing.. it is named fr_FR
# french
test=French Test
my english file has this
# english
test=Test
If I set the compile line to just -locale en_US
then when I switch back and forth, the english label will show up, but when I switch to French, the label disappears, which makes sense
but when I change my compile line to -locale en_US,fr_FR
then I get the "unable to open 'local/en_US,fr_FR'
I think this is sooooo close to working
DasaPaddock
Use:
-locale=en_US,fr_FR
DebbieAlger
Dasa,
You are a Genius!!! That picked up my French translations. I am worried tho that it didn't pick up the standard French for the rest of the GUI,
such as "I want to" and "More" options, I thot everything that I don't do would have changed. But, I will work on that later.
Thanks so much, you can take the weekend off now, I am Golden!
