Reproject in map service or not?
981
08-23-2011 07:27 AM
MarcWeinshenker1
I have a dynamic operational layer in Maryland State Plane that I am placing over the ESRI basemap (Web Mercator) and it works fine.  What I started wondering, though, was whether or not I should reproject in the map service by setting the data frame to Web Mercator instead of MD State Plane and then bring in the feature class and specify the transformation.  Does it matter to what happens when the Flex map is composed in terms of the server effort to process the data or to feature registration (no measurements will be involved)?
Marc
RobertScheitlin__GISP
Marc,
   You will always get better server response when all map services are in the same WKID.
MarcWeinshenker1
Robert,
Thanks very much.
