Remove Widget Icons in Flexviewer 2
1018
12-08-2010 10:50 AM
EmilyLaMunyon
I have looked in the forums and have not been able to find a thread relating to this. When I add new widgets to the flexviewer an icon appears in the header of the map. Is there a way to remove these? The widgets I have added function without needing to push a button. I am hoping it is something simple I have missed.
Thanks!
DasaPaddock
If you put them outside of a widgetcontainer, then they won't appear in the HeaderController.
RobertScheitlin__GISP
Emily,
    Be sure to post FlexViewer questions to the Flex Viewer forum.
http://forums.arcgis.com/forums/111-...iewer-for-Flex
If you don't want the widget to appear in the header than make sure you do not put it inside a widgetcontainer element.
EmilyLaMunyon
Thanks Robert and Dave, that worked.
Sorry about posting in the wrong forum, I will be more careful in the future:o
