Remove selections from a FeatureLayer
2361
09-09-2010 07:51 AM
ReneRubalcava
Esri Frequent Contributor
I was curious if there was a clean way to remove particular selections from a Featurelayer.
I tried a couple of different methods to limit the selection to first selected feature.
I thought I could cheat and splice the selectedFeatures
var x:uint = featurelayer.selectedFeatures.length;
featurelayerselectedFeatures.splice(1,x);
But that didn't work.
Then I tried to grab the first graphic and make a new FeatureCollection
var g:Graphic = featurelayer.selectedFeatures[0];
featureLayer.featureCollection = new FeatureCollection(new FeatureSet());
That didn't work either.
The next step I suppose would be to use the first graphic geometry to do second selection query on the FeatureLayer, but that seems a bit heavy handed.
The reason I am using FeatureLayer is that this is for a custom component and it is much simpler to pass a FeatureLayer with built in query/selection capabilities than to pass a QueryTask URL and an existing GraphicsLayer on the Map, plus it fits into my workflow as I have some listeners in the main app for when a selection ends on the FeatureLayer being passed.
If there's no way to tweak the SelectedFeatures after the fact, I'll just go the QueryTask/GraphicsLayer route, but I figure it couldn't hurt to ask.
DasaPaddock
You can call selectFeatures() where the selectionMethod is SELECTION_SUBTRACT.
Reference:
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/FeatureLayer.html#selectFeatures()
ReneRubalcava
Aha, that did the trick!
Thanks Dasa.
