Radio Button on/off Layers
8890
18
04-07-2010 12:45 PM
MattWilliams
After an entire day of attempting this, I'm hoping to find some answers here on the forum. It appears I've bitten off more than I can chew. What I'm trying to do is create a set of radio buttons that turn on different layers from a dynamic service. When a radio button is clicked it makes a layer visible and the previously visible layer is turned off.  (i.e. Only one layer is visible at a time)
I've been trying to modify the sample: Dynamic Map Layers on/off, but this has turned into a giant mess. Its just not designed for radio buttons. I had wanted some intelligence (using an array) built into my code, but I'm totally fine for just hard coding it in. Here's a chunk my relevant mxml
  <esri:Map>
     <esri:extent>
            <esri:Extent xmin="-91.17" ymin="40.944" xmax="-90.37" ymax="41.4">
                <esri:SpatialReference wkid="4326"/>
            </esri:Extent>
        </esri:extent>
        <esri:ArcGISDynamicMapServiceLayer id="depthDyn"
            url="http://blackberry.sws.uiuc.edu/ArcGIS/rest/services/FlexDev/Depth/MapServer" />
    </esri:Map>
<mx:Panel width="300" height="250" x="20" y="250" paddingLeft="20">
  <mx:RadioButtonGroup id="cb" itemClick="radioClick(event);"/>
      <mx:RadioButton groupName="cb" id="depth500" value="m500" label="Mercer500" width="150"/>
      <mx:RadioButton groupName="cb" id="depth200" value="m200" label="Mercer200" width="150"/>
      <mx:RadioButton groupName="cb" id="depth100" value="m100" label="Mercer100" width="150"/>
      <mx:RadioButton groupName="cb" id="depth50" value="m50" label="Mercer50" width="150"/>
      <mx:RadioButton groupName="cb" id="depth10" value="m10" label="Mercer10" width="150"/>
</mx:Panel>
BenKane
I am looking to implement radio buttons to turn on only one layer at a time through a TOC or LayerSelect widget in Flex Viewer.  Specifically, I want to enable only one polygon feature to be displayed at a time, but I would like to allow multiple point and line features to be displayed simultaneously.  Does anybody have a code solution or tips for this?
Ben K
KomanDiabate
Does anybody knows how to change to this great code to use checkbox instead. I was able to show check box instead of option buttons (see below), however, when I hit the checkboxes to turn on and off layer nothing happens. Thanks in advance.
private function loadLayerName():void
    layerPanel.removeAllChildren();
    //loop through each layer and add as a radiobutton
    for(var i:uint = 0; i < (dynamicLayer.layerInfos.length); i++)
     var chks:CheckBox = new CheckBox;
     chks.name="{checks}"
     chks.label= dynamicLayer.layerInfos.name;
     layerPanel.addChild(chks);
MarkHoyland
You will need to add an event listener when the ckeckbox is created.
In the handler you would then have to add or remove the layer from the visiblelayers arraycollection.
//add event listener
 chks.addEventListener(Event.CHANGE, chk_changeHandler);
protected function chk_changeHandler(event:Event):void
 var checkBox:CheckBox = event.currentTarget as CheckBox;
 if (checkBox.selected = true)
  trace("check is selected");
  //add to visiblelayers
 else
  // remove from visiblelayers
KomanDiabate
Hi Mark,
Thanks for the reply, I have flex 4.6 at work trying to redo the initial code using flex 4.6, looks like the way you handle RadioButtonGroup is totally changed from flex 3 to flex 4. Need to convert this code to flex 4 first and then test your logic. I am bit stuck.
So, Flex 4 didn't like layerPanel.addChild(radioBtn)
Change to: layerPanel.addElement(radioBtn); only on button is loaded and all the text are overlapped.
Any help in that direction will be definitely appreciated.
[ATTACH=CONFIG]17098[/ATTACH]
Thanks.
MarkHoyland
Hi Koman,
You now need to set the panel's layout inside the panel.
(In the VerticalLayout tag you can set any padding ang gap etc.)
<s:Panel>
 <s:layout>
  <s:VerticalLayout paddingTop="10" gap="2"/>
 </s:layout>
</s:Panel>
KomanDiabate
Hi Mark,
The panel worked wonderfully, the radio button are loaded correctly but when clicked the layers don't turn on/off. I am still migrating from 3 to 4, I am a bit still struggling with this.
Here is the question: With Flex 3 the radioButton is loaded directly in the panel and with Flex 4 the <s:RadioButtonGroup> it set in <fx:Declaration> and the< Radiobutton> item are loaded in the panel. I think because of this when I clicked the radioBtnGroup_itemClickHandler is not being fired. Do I need additional steps to make this work. I am little bit perplexed by this. Thank you so much.
<fx:Declarations>
  <s:RadioButtonGroup id="radioBtnGroup" itemClick="radioBtnGroup_itemClickHandler(event)" />
  <!-- Place non-visual elements (e.g., services, value objects) here -->
 </fx:Declarations>
 <esri:Map id="myMap">
  <esri:extent>
   <esri:Extent xmin="-126" ymin="27" xmax="-72" ymax="50">
   </esri:Extent>
  </esri:extent>
  <esri:ArcGISDynamicMapServiceLayer id="dynamicLayer"
    load="loadLayerName()"
   url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/{myURL.selectedItem}/MapServer" />
 </esri:Map>
 <mx:ComboBox id="myURL" selectedIndex="0" horizontalCenter="0">
  <fx:Array>
   <fx:String>Specialty/ESRI_StateCityHighway_USA</fx:String>
   <fx:String>Specialty/ESRI_StatesCitiesRivers_USA</fx:String>
   <fx:String>Demographics/ESRI_Census_USA</fx:String>
  </fx:Array>
 </mx:ComboBox>
 <s:Panel id="layerPanel" y="250" width="300" height="250" horizontalCenter="0" >
  <s:layout>
  </s:layout>
  <s:RadioButton label="Button 1" groupName="radioBtnGroup"/>
  <s:RadioButton label="Button 2" groupName="radioBtnGroup"/>
 </s:Panel>
MarkHoyland
Hi Koman,
If you look at the adobe help for 4.6 radiobutton, the sample shows it uses the 'group'  property instead of the 'groupName'
http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf69084-7d8b.html#WS2db454920e96...
Yours should be
<s:RadioButton label="Button 1" group="{radioBtnGroup}"/>
Anyhow here is the original code ported to spark
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:esri="http://www.esri.com/2008/ags">
 <s:layout>
  <s:VerticalLayout/>
 </s:layout>
 <fx:Script>
  <![CDATA[
   import com.esri.ags.events.LayerEvent;
   import mx.collections.ArrayCollection;
   import mx.events.ItemClickEvent;
   import spark.components.RadioButton;
   protected function loadLayerName(event:LayerEvent):void
    layerPanel.removeAllElements()
     var radioBtn:RadioButton = new RadioButton;
     radioBtn.group = radioBtnGroup;
     radioBtn.value = i;
     radioBtn.label = dynamicLayer.layerInfos.name;
    //set the visible layer the first radio button
    radioBtnGroup.selectedValue = 0;
    dynamicLayer.visibleLayers = new ArrayCollection([0]);
   protected function radioClickHandler(event:ItemClickEvent):void
    // update the visible layers to only show the layer selected
    dynamicLayer.visibleLayers = new ArrayCollection([event.index]);
 </fx:Script>
 <fx:Declarations>
  <s:RadioButtonGroup id="radioBtnGroup" itemClick="radioClickHandler(event)"/>
 </fx:Declarations>
  <esri:extent>
   </esri:Extent>
  </esri:extent>
    load="loadLayerName(event)"
 </esri:Map>
 <s:ComboBox id="myURL" selectedIndex="0" horizontalCenter="0" width="300">
  <s:dataProvider>
   <s:ArrayList>
   </s:ArrayList>
  </s:dataProvider>
 </s:ComboBox>
 <s:Panel id="layerPanel" width="300" height="250" x="20" y="250">
  <s:layout>
   <s:VerticalLayout paddingTop="10" paddingBottom="10" paddingLeft="10" paddingRight="10"/>
  </s:layout>
 </s:Panel>
</s:Application>
KomanDiabate
Hi Mark,
Thank you so much for the code, it helps me understand what I was doing wrong. This is a simple/clean way to do layer on/off, I will definetely put it to good use. Thanks again.
KomanDiabate
Hi Mark,
I am now trying to use the same example with checkboxes. I was assuming it should be fairly simple, but I admit, I'm wrong.
So, I am able to load the layers in checkboxes, however, I am not able to have to code work in such way that: when I clicked on the checkbox the layer come on or off. Using dynamicLayer.visibleLayers = new ArrayCollection([5]); layer #6 get turned on but doesnt turned off. I have tried several different thing with no satisfactory result. Any help will be appreciated.
Thanks.
[ATTACH=CONFIG]17233[/ATTACH]
