put draw extent and sync with datagrid sample together
2181
05-16-2011 01:38 PM
MikeJun
I created a button to select a graphic(points) with polygon extent. What I'd like to do is when it selects points, its attributes are populated in datagrid and highlight corresponding graphic when mouse over on an each item in datagrid.
I got it to work except highlight corresponding graphic from datagrid.
<?xml version="1.0" encoding="utf-8"?>
<mx:Application
    xmlns:mx="http://www.adobe.com/2006/mxml"
    xmlns:esri="http://www.esri.com/2008/ags"
    layout="horizontal"
    creationComplete="doQuery()">
    <mx:initialize>
     <![CDATA[
      drawToolbar.activate(Draw.EXTENT);
    </mx:initialize>
    <mx:Script>
        <![CDATA[
            import mx.collections.ArrayCollection;
            import com.esri.ags.geometry.MapPoint;
            import com.esri.ags.geometry.Extent;
            import com.esri.ags.events.DrawEvent;
            import mx.controls.Alert;
            import com.esri.ags.Graphic;
            import mx.rpc.AsyncResponder;
            import com.esri.ags.tasks.Query;
            import com.esri.ags.tasks.QueryTask;
            import com.esri.ags.tasks.FeatureSet;
            import mx.events.ListEvent;
            private function doQuery():void
                queryTask.execute(query, new AsyncResponder(onResult, onFault));
                function onResult(featureSet : FeatureSet, token:Object = null):void
                    for each(var graphic:Graphic in featureSet.features)
                        myGraphicsLayer.add(graphic);
                function onFault(info:Object, token:Object = null) : void
                    Alert.show(info.toString());
            private function drawEndHandler(event:DrawEvent):void
                var extent:Extent = event.graphic.geometry as Extent;
                var graphic:Graphic;
                var results:ArrayCollection = new ArrayCollection;
                for (var i:Number = 0 ; i < myGraphicsLayer.numChildren ; i++)
                    graphic = myGraphicsLayer.getChildAt(i) as Graphic;
                    //if point is contained within extent, highlight it and add for display in results list
                    if (extent.contains(MapPoint(graphic.geometry)))
                        graphic.symbol = highlightedSymbol;
                        results.addItem({CITY_NAME: graphic.attributes.CITY_NAME, STATE_NAME:graphic.attributes.STATE_NAME});
                    //else if point was previously highlighted, reset its symbology
                    else if (graphic.symbol == highlightedSymbol)
                        graphic.symbol = defaultSymbol;
                labelPoints.text = "# of points in extent = " + results.length;
                dg.visible = true;
                dg.dataProvider = results;
           //Sync map and datagrid interaction
   private var highlightedGraphic:Graphic;
            private function onItemRollOver(event:ListEvent):void
                if (highlightedGraphic) { highlightedGraphic.symbol = resultsSymbol; }
                highlightedGraphic = findGraphicByAttribute(event.itemRenderer.data)
                highlightedGraphic.symbol = highlightedSymbol;
            private function onItemRollOut(event:ListEvent) : void
                findGraphicByAttribute(event.itemRenderer.data).symbol = resultsSymbol;
            public function findGraphicByAttribute(attributes:Object):Graphic
                for each( var graphic:Graphic in myGraphicsLayer.graphicProvider)
                    if (graphic.attributes === attributes)
                        return graphic;
                return null;
    </mx:Script>
    <!-- Start Declarations -->
        <esri:SimpleMarkerSymbol id="defaultSymbol" color="0x0000FF" style="circle" size="12" alpha="0.5">
            <esri:SimpleLineSymbol/>
        </esri:SimpleMarkerSymbol>
        <esri:SimpleMarkerSymbol id="highlightedSymbol" color="0xFF0000" style="circle">
        <esri:SimpleFillSymbol id="sfs" style="solid" alpha="0.5" color="0x000000">
            <esri:SimpleLineSymbol color="0xFF0000"/>
        </esri:SimpleFillSymbol>
        <esri:SimpleMarkerSymbol id="resultsSymbol" style="circle" size="24" alpha="0.8" color="0x52F3FF"/>
        <esri:Draw id="drawToolbar" map="{myMap}" fillSymbol="{sfs}" drawEnd="drawEndHandler(event)"/>
    <!-- End Declarations -->
    <esri:QueryTask id="queryTask" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map..." />
    <esri:Query id="query" where="STATE_NAME = 'Washington'" returnGeometry="true" outSpatialReference="{myMap.spatialReference}">
     <esri:outFields>
             <mx:String>CITY_NAME</mx:String>
             <mx:String>STATE_NAME</mx:String>
            </esri:outFields>
    </esri:Query>
    <mx:VBox width="100%" height="100%">
        <mx:Text text="Draw a rectangle to select points within an extent" fontSize="12" fontWeight="bold" width="100%"/>
        <esri:Map id="myMap">
            <esri:extent>
                <esri:Extent xmin="-125.9" ymin="44.6" xmax="-114.6" ymax="50.2">
                    <esri:spatialReference>
                        <esri:SpatialReference wkid="4326"/>
                    </esri:spatialReference>
                </esri:Extent>
            </esri:extent>
            <esri:ArcGISTiledMapServiceLayer
                url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/>
            <esri:GraphicsLayer id="myGraphicsLayer"/>
        </esri:Map>
    </mx:VBox>
    <mx:VBox width="240" height="100%">
        <mx:Text id="labelPoints" fontSize="12" fontWeight="bold" width="100%"/>
        <mx:DataGrid id="dg" width="100%" height="100%" itemRollOut="onItemRollOut(event)" itemRollOver="onItemRollOver(event)"
         dataProvider="{queryTask.executeLastResult.attributes}" visible="false">
            <mx:columns>
                <mx:DataGridColumn dataField="CITY_NAME"/>
                <mx:DataGridColumn dataField="STATE_NAME"/>
            </mx:columns>
        </mx:DataGrid>
    </mx:VBox>
</mx:Application>
TracySchloss
Honored Contributor
I know this is an older post.  Did you ever get this to work?
