Problem with minimum scale visibility
689
08-26-2011 03:15 AM
LuisJimenez
We are having problems with the minimum scale visibility in a flex project using esri library.
We set the scale in map (using scale property) to 7000 (that is the minium scale of the layer) but the layer doesn't appear (is not visible in map).
If we debug, after setting the scale to 7000 we can see that scale property of the map is something like 7000.00000000823, so the scale is above 7000 and the layer is not visible.
Is this a bug? Someone has haved a similar issue?
Thanks in advance!
