Problem with Identify and using domains from Geodatabases
811
06-21-2010 10:14 AM
RichardButgereit
Something I have noticed is that identify and query through the Flex viewers and REST services do not report any values described with domains from a geodatabase.
If you add a service in ArcMap and/or ArcGIS Explorer, and identify a feature, you will get the description and not the code. But if you use a Flex viewer and/or the REST Services Directory, the code will be reported, not the description from a domain in the geodatabase.
I really need some help figuring this out right now.
RobertScheitlin__GISP
Richard,
   Nothing much to figure out that you have not already... Domains values are not returned from REST in ArcGIS Server 9.3.1 and below. The domain values will be available in ArcGIS Server 10. There is no workaround for ArcGIS Server 9.3.
