Print Functionality
848
10-29-2010 05:17 AM
ChadHall
I've perused through the forums about printing and seen topics on ActivePDF and then there's the export function through the REST end (which if I'm starting to get a handle on this means you have to have the uncompiiled version to make your mods/adds and then recompile).
I half feel like I'm pressing my luck here because so far, everything I've had a question for someone has shown me the way (thanks again Robert and Karl).  But I'm persistent so I'll try.
ArcIMS had scripts and add-on's so you could modify the html code to print or export to pdf or change the page size and orientation of the print function.  Is there a similar widget with this functionality?  Also, and more pointedly at ESRI I suppose, why isn't this included with the base Sample Flex Viewer?  I'm using the compiled version of the sample flex viewer running 9.3.  Any help would be greatly appreciated.
Chad
KarlWilson
I guess there are 3 options to get your map onto paper one way or another:
Karl
