Populate Combobox from FeatureSet
2941
14
10-12-2010 07:46 AM
DonCaviness
I have a combobox that I want to populate with a field that is being returned in a featureSet from a query.  I am querying a table and getting the results but I am having trouble figuring out what I am missing to populate the combobox.  Here is the code I am using.  Can anyone see what I am doing wrong?
for each (var graphic:Graphic in featureSet.features)
 var category:String = graphic.attributes.category;
 var subcat:String = graphic.attributes.subCategory;
 var data:Object = {
  category: category,
  subcat: subcat
 cboCategory.dataProvider = data.subcat;
DasaPaddock
Drew
Also.. Set your dataProvidor outside of the loop...
Here is a working sample of code populating a combo box.
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" xmlns:esri="http://www.esri.com/2008/ags">
 <mx:Script>
  <![CDATA[
   import mx.controls.Alert;
   import mx.collections.ArrayCollection;
   import com.esri.ags.Graphic;
   import com.esri.ags.tasks.FeatureSet;
   import com.esri.ags.events.QueryEvent;
   private function queryData():void
    queryTask.execute(query);
    queryTask.addEventListener(QueryEvent.EXECUTE_COMPLETE, onQueryComplete);
   private function onQueryComplete(event:QueryEvent):void
    var featureSet:FeatureSet = event.featureSet;
          var results:ArrayCollection = new ArrayCollection();
     var fieldValue:String = graphic.attributes["STATE_NAME"].toString();
     results.addItem({label: fieldValue, data:graphic});
          cmb.labelField = "label";
          cmb.dataProvider = results;
 </mx:Script>
        <esri:QueryTask
            id="queryTask"
            url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"/>
        <esri:Query
            id="query"
            returnGeometry="false"
            where="1=1"
            outFields='["STATE_NAME"]'/>
 <mx:ComboBox id="cmb" x="179" y="205" labelField=""></mx:ComboBox>
 <mx:Button x="87" y="205" label="Load Data" click="queryData();"/>
</mx:Application>
Drew
NadeemShaukat
 <mx:Script>
  <![CDATA[
 </mx:Script>
        <esri:QueryTask
            id="queryTask"
        <esri:Query
            id="query"
            where="1=1"
</mx:Application>
Drew
Drew,
Have you tried this sample. When I compiled and ran this sample, it's complaining about FeatureSet. The error message is "1046: Type was not found or was not a compile-time constant: FeatureSet."
Do you have any idea?
nshaukat
Drew
It could be a AGS Flex API version issue that's causing the problem.
The sample provided looks like its using the 1.3 lib.
Drew
Here is an upgraded version for the 2.1 lib.
 <mx:Script>
  <![CDATA[
   import com.esri.ags.FeatureSet;
 </mx:Script>
 <esri:QueryTask
  id="queryTask"
  useAMF="false"
 <esri:Query
  id="query"
  where="1=1"
</mx:Application>
Drew
NadeemShaukat
Thanks Drew. It worked.
Do you know if there is way to populate the combobox without using "QueryData" function so I do not have to push the "Load Data" button.
nshaukat
Drew
nshaukat
you will want to do it on creationComplete
sample
<mx:Application creationComplete="creationCompleteHandler(event)"
    layout="absolute"
 <mx:Script>
  <![CDATA[
   import mx.events.FlexEvent;
   protected function creationCompleteHandler(event:FlexEvent):void
    queryData();
 </mx:Script>
 <esri:QueryTask
  id="queryTask"
  useAMF="false"
 <esri:Query
  id="query"
  where="1=1"
</mx:Application>
NadeemShaukat
Drew,
Thanks much for your prompt response.
nshaukat
NadeemShaukat
I thought I was on my way to populate combo boxes using this sample. But when I was going to modify it for multiple combo boxes filled with different fields from one or more services, it brings up "Object Object" in one of the combo boxes instead of right values. Any suggestions from anyone who has used this sample for similar conditions. Any help will be much appreciated.
nshaukat
