Pop-up Window for the Dynamic Map Layer
796
12-14-2011 05:49 AM
JinnanZhang
Hello,
I have a problem here and really hope somebody could give me some suggestions.
I created a customized widget for Flex Viewer which will only allow user to switch on one layer at a time. The layers are dynamic map layers. I am now trying to add the pop-up window function to those layers but really cannot make it work since I am not getting those layers from the main configuration XML; and they are not feature layers.
Anybody know how can I add the pop-up function for the Dynamic Map Layer?
Thanks a lot.
DasaPaddock
JinnanZhang
See the createPopUpRenderer() function at https://github.com/ArcGIS/ArcGISViewerForFlex/blob/master/src/com/esri/viewer/managers/MapManager.mx...
Hi Dasa, thank you for your reply. Could you please give me an example about how to use the "layerInfoWindowRenderer" property for the dynamic map layer?
Thanks a lot.
Jinnan
