Poll: Should we have a separate forum for ArcGIS Viewer for Flex?
1174
06-30-2010 04:39 PM
BjornSvensson
Esri Alum
What do you think?  Take the poll.
We are thinking to maybe split it into
- Flex Viewer (people working with configuration files)
- Flex API (including people using Flash Builder to work with the source code for the viewer)
This has the potential for confusion when you are a Flex developer working with the viewer source code. Is my question more of "API" or more of "Viewer"? I think the answer would usually be "API".  Also, with two forums, people who are not compiling the Flex Viewer will not have to see all the "API" questions.
TonyCollins
Would you still keep the Flex API forum available for those who are writing apps not based on the Flex Viewer?
BjornSvensson
Esri Alum
Yes, I think the one for API would be both for "API only users" as well as for "API use based on viewer code".
BjornSvensson
Esri Alum
The Flex API forum has long been a place for both the Flex API and Flex Viewer.  As of today there is now a separate forum for "ArcGIS Viewer for Flex"
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
If you have questions about the Flex Viewer, feel free to use http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
If you have questions more specific to the Flex API itself, feel free to keep using http://forums.arcgis.com/forums/18-ArcGIS-API-for-Flex
CattyannCampbell
Thanks for the separation, however, I would like to see some of the older FSV discussions here...
