PDC widget problem
962
09-21-2010 08:48 AM
BobbySells
I loaded the PDC widget and it is great, however now I get an error when i try to load any other widget. I assume it is with the widget template. i get the following error.
TypeError: Error #2007: Parameter name must be non-null.
at flash.display::DisplayObject/set name()
at com.esri.solutions.flexviewer::WidgetTemplate/addTitlebarButton()
at com.esri.solutions.flexviewer::WidgetTemplate/createChildren()
at mx.core::UIComponent/initialize()
at mx.core::Container/initialize()
at com.esri.solutions.flexviewer::WidgetTemplate/initialize()
at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::childAdded()
at mx.core::Container/http://www.adobe.com/2006/flex/mx/internal::childAdded()
at mx.core::Container/addChildAt()
at mx.core::Container/addChild()
BobbySells
what i mean is if i select a widget from the widgets menu it errors with that error, the clock just spins and it cannot load the minimized state of the widget on the right side of the menu.
Bobby
