pass map between views in a ViewNavigatorApplication
2088
6
03-15-2013 07:03 AM
MarkYerington
What I am trying to do is develop a simple mobile application in Flash 4.6.  I am trying to add layers to a main view based on what is selected in the Table of contents view in a second view.  It is a series of check boxes that I would like to select maps and load those into the main map.  I have most of the functionality worked out I just can't get the map reference to pass to the other views.
ChrisNorth
Do you have two separt map controls in the flex application?  If so,  one method is to loop through each layer in map 1 and add the layers one by one to map 2. I do this for a print preview.  Something like...
private function cloneMap():void
  layerCount = 0;
  for (var i:Number = 0; i < map1.layerIds.length; i++)
    var layer:Layer = map1.getLayer(map.layerIds);
    if (layer is ArcGISDynamicMapServiceLayer)
      layerCount = layerCount + 1;
      var dynamicLayer:ArcGISDynamicMapServiceLayer = layer as ArcGISDynamicMapServiceLayer;
      var newdl:ArcGISDynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer(url, proxyurl, token);
      newdl.proxyURL = dynamicLayer.proxyURL;
      newdl.token = dynamicLayer.token;
      newdl.alpha = dynamicLayer.alpha;
      newdl.visible = dynamicLayer.visible;
      newdl.visibleLayers = dynamicLayer.visibleLayers;// visiblelyrs;
      newdl.layerDefinitions = dynamicLayer.layerDefinitions;
      newdl.name = dynamicLayer.name;
      newdl.addEventListener(LayerEvent.LOAD, layerLoadComplete);
      map2.addLayer(newdl);
   //... you need to handle all layer types individually, and figure out what you need to transfer.
Chris
MarkYerington
No I just have one map control.  What it essentially is, is that I have a map control on the Map View Tab. Then on the TOC tab there are a series of check boxes that I would like to select the layers that are added to the Map Control on a map view tab.  My problem is that I cannot reference the Map Control on the map view tab of the application.
JustinWilson
In the control you want the map to be used add code similar to:
import com.esri.ags.Map;
private var _map:Map
public function set Map(value:Map):void{
     _map = value;
Then, from your application - pass a reference to the Map property of your control.  Now you can add and remove what you want from your map with your checkbox controls.
tab.Map = myMap
It's difficult to solve without knowing more about your application, but I hope this might help.
DasaPaddock
MarkYerington
Ok don't think I have this set up right.  I have two views in a tabbed view navigator mobile app.  I have been trying to pass the map from the Map View to the TOC view so I can turn layers on and off then push back to the map view.  Here are my functions.
Map View Function
private function onClick(event:MouseEvent):void {
navigator.pushView(views.ToolsView,myMap);
"myMap" is the id of the map on the map view.
TOC View Functions
protected var map:Map;
override public function set data(value:Object):void{
    super.data = value;
    map = value as Map;
Trying to add layer to map
if (cb.selected)
     control = new ArcGISDynamicMapServiceLayer("http://xxxxxxxxxx/arcgis/rest/services/MAGIC_Landbase/MuscatineCo_SurveyControl/MapServer");
     control.visible = true;
     map.addLayer(control)
It always errors on the map.addLayer saying cannot access property with null object reference.  I am very new to the mobile framework, so trying to use the examples that were posted.
YannCabon
Can you verify that "myMap" in not null before calling pushView ?
