Parcel Notification Widget-will this work on Flex 2.1
4424
12
10-04-2010 08:34 PM
JayDira
I found a Parcel Notification widget that was created in flex 1.3. Will this parcel notification widget work for Flex 2.1?
THanks.
philippschnetzer
fixed that error by using import spark.components.ComboBox rather than its mx counterpart.  But now on to a new error:
1020: Method marked override must override another method
Here's a portion of the affected code (from the AutoComplete.as file):
package myWidgets.ParcelNotificationWidget
import flash.events.Event;
import flash.events.FocusEvent;
import flash.events.KeyboardEvent;
import flash.net.SharedObject;
import flash.ui.Keyboard;
import mx.collections.ArrayCollection;
import mx.collections.ListCollectionView;
import mx.core.UIComponent;
import spark.components.ComboBox;
 //  Overridden Properties
 //  editable
  *  @private
  override public function set editable(value:Boolean):void
     //This is done to prevent user from resetting the value to false
     super.editable = true;
  *  @private
  override public function set dataProvider(value:Object):void
  super.dataProvider = value;
  if(!usingLocalHistory)
   tempCollection = value;
The error has to be attributed to Flash Builder 4 since this code worked perfectly in Flex Builder 3 / SDk 3.3.....
THANK YOU!!!!
JayDira
Hi Phillip,
Has there been a resolution for you error?
 //  editable
  *  @private
  *  @private
THANK YOU!!!!
philippschnetzer
Dira,
I decided to scrap getting this to work in 2.1 when the eSearch widget was released.  This widget has all the capabilities that the old parcel notification widget had plus some...
Check it out:
http://forums.arcgis.com/threads/15783-Enhanced-Search-Widget-for-FlexViewer-2.1?
