Parcel Notification Widget error
12407
50
06-02-2010 07:25 AM
MuhammadKhokhar
Hello, I am new to flex API and was trying to implement the Parcel Notification Widget. I have looked over the forums and fixed some errors but I am getting a error #2007.
TypeError: Error #2007: Parameter blendMode must be non-null.
at flash.display::DisplayObject/set blendMode()
at mx.skins.halo::HaloFocusRect/updateDisplayList()
at mx.skins::ProgrammaticSkin/validateDisplayList()
at mx.managers::LayoutManager/validateDisplayList()
at mx.managers::LayoutManager/doPhasedInstantiation()
at Function/http://adobe.com/AS3/2006/builtin::apply()
at mx.core::UIComponent/callLaterDispatcher2()
at mx.core::UIComponent/callLaterDispatcher()
I dont know what mistake I am doing. My xml is below,
<configuration>
<!--Parcel Service for QueryTask-->
<parcels>http://neccog-rip/ArcGIS/rest/services/Maps/PutnamWGS84/MapServer/0</parcels>
<!--Geometry Service for Buffer-->
<geometryservice>http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer</geometryservice>
<!--Locator for address geocode-->
<locator>http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Locators/ESRI_Geocode_USA/GeocodeServer</locator>
<!--Result Zooom Scale-->
<zoomscale>5000</zoomscale>
<!--Select Parcel by Field ("Field","Field Alias")-->
<findparcelfield>NPARNO,National Parcel Number</findparcelfield>
<!--Use parcel autocomplete box ('T' = true, 'F' = false)-->
<!--ArcGIS Server will only return 500 results by default.  If defaults changed and a large number of features returned widget load may take a longer time to complete-->
<autocomplete>T</autocomplete>
<!--Default Parcel ID-->
<defaultparcelid>CT-000-000-000-000</defaultparcelid>
<!--Select Parcel by Address Field -->
<findparceladdressfield>SITEADD</findparceladdressfield>
<locatoraddressfield>Address</locatoraddressfield>
<!--State ComboBox for search by address-->
<listfield>State</listfield>
<listvalues>CA,CO,CT,DE,DC,FL,GA,HI,IA,ID,IL,IN,KS,KY,LA,MA,MD,ME,MI,MN</listvalues>
<!--Default Address-->
<defaultaddress>216 Fox Rd,Putnam,CT,06260</defaultaddress>
<!--Minimum Score for Geocode-->
<minscore>80</minscore>
<!--Parcel Map Tip Fields ("Field","Field Alias")-->
<!--Fields with "$" formatted as currency-->
<maptip>NPARNO,National Parcel Number;SITEADD,Full Site Address</maptip>
<!--Parcel content for widget ("Field","Field Alias")-->
<parcelcontent>NPARNO,National Parcel Number;SITEADD,Full Site Address</parcelcontent>
<!--Fields to include in output .csv table ("*" = All fields)-->
<csvfields>*</csvfields>
<!--Default .csv file name-->
<csvdefaultname>Selected Parcels</csvdefaultname>
</configuration>
ShawnKraft
configuration>
<parcels>http://icarus/ArcGIS/rest/services/StreetStuff/MapServer/6</parcels>
<findparcelfield>PIN,ID</findparcelfield>
<defaultparcelid>16742620002000</defaultparcelid>
<findparceladdressfield>SITUSFULLA</findparceladdressfield>
<listvalues>AK,AL,AR,AZ,CA,CO,CT,DE,DC,FL,GA,HI,IA,ID,IL,IN,KS,KY,LA,MA,MD,ME,MI,MN,MS,MO,MT,NC,ND,NE,NH,NJ,NM,NV,NY,OH,OK,OR,PA,RI,SC,SD,TN,TX,UT,VA,WA,WI,WV,WY</listvalues>
<defaultaddress>221 HWY 130,LARAMIE,WY,82072</defaultaddress>
<parcelcontent>PIN,ID;SITUSFULLA,Address;NAME,Owner Name</parcelcontent>
<maptip>PIN,ID;SITUSFULLA,Address;NAME,Owner Name</maptip>
</configuration>
ShawnKraft
I posted the parcel locator stuff cuz that ended up not working right like I thought it was.  So I figure if I get the parcel locator working right then the parcel notification should be the same set up.
RobertScheitlin__GISP
Shawn,
   So what is the Parcel Locator doing? What is the error?
ShawnKraft
It doesn't generate any errors.  It operates like it should but it just has problems with finding some of my addresses.
Shawn,
   Not finding some of your addresses is not unusual. Try setting the minscore to 60.
ShawnKraft
Okay if that is it, someone needs to smack me for not figuring that out.
ShawnKraft
That worked.  The addresses it was not finding was because they are pretty new addresses and ESRI probably doesn't have them updated in their geocoding service yet.  I probably should set up a geocoding service of my own n use it.
ShawnKraft
My problem was that when I originally started building with flex, I was using sdk 3.3.  I started adding things and then switched to sdk 3.5.  So I scrapped it all and began with 3.5 and its all working as it should now.  I appreciate the help.  I read somewhere where you said that you need to be consistent with the version you are using throughout.  Mixing them could cause problems and it did cause mine.
MuhammadKhokhar
I have tried many changes but I am still getting the error : (Error #2007: Parameter blendMode must be non-null.) I downloaded a new SFV and ParcelLocatorWidget but it gives me the error. Does any one know what I can do to solve this problem.
Both the viewer and widget were built in the 3.3 SDK so shouldnt they work?
Muhammad,
   Try updating to the 3.5 SDK.
