Overview Map not working with BingLayers in FlexViewer
4060
10
07-29-2010 07:23 AM
ScottBeaumont
In the beta 2.0 FlexViewer, I've changed the config.xml file to use bing layers instead of the default tiled layers from ArcGISOnlie.  Everything works great, except for the overview map.  When I use the Bing layers, the overview map is blank.  Any thoughts?  I've posted the map config section below where I changed the basemap layers to bing.
<map initialextent="-14083000 3139000 -10879000 5458000">
        <basemaps>
            <mapservice label="Streets" type="bing" visible="false"  alpha="1"
                 key="Al0VE_jsmagxk4LFghXGlK5JSHfC0tk-eHRubZv_eMYm6wzgQaStYks8g-wWcgk3"
                 style="road"/>
            <mapservice label="Aerial" type="bing" visible="false" alpha="1"
                   style="aerial"/>
            <mapservice label="Hybrid" type="bing" visible="false" alpha="1"
              style="aerialWithLabels"/>
        </basemaps>
        <operationallayers>
            <layer label="Boundaries and Places" type="tiled" visible="false"
                   url="http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places_Alternate/MapServer"/>
            <layer label="Fires" type="feature" visible="false" alpha="1"
                   info="widgets/InfoTemplates/SimpleInfoWinWidget.swf"
                   infoconfig="widgets/InfoTemplates/IWT_Fires.xml"
                   url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0"/>
        </operationallayers>
    </map>
RobertScheitlin__GISP
Scott,
   Have you changed your OverviewMapWidget.xml?
ScottBeaumont
No, I have not.  I was under the impression that it would use the same layers that the base map uses by default.  Here is the OverViewMapWidget.xml:
<?xml version="1.0" ?>
<configuration>
    <!-- possible values for initialstate: open or closed (default) -->
    <initialstate>closed</initialstate>
    <!-- by default it will use the same basemap as current main map,
         you can hardcode as below if you wish -->
    <!-- <mapservice
            type="tiled"
            mode="dynamic"
            url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
</configuration>
Scott,
   You don't have to I was just wondering if you had. I will test this bing maps on my end and let you know.
ScottBeaumont
Awesome... thanks for the help.
MehulChoksey
If config file for overview map does not specify layer, then overview map should have same layer as base map. Thanks for reporting this bug.  We have filed issue in our system
SarthakDatt
Hey Scott,
Can you try adding culture property to your bing map service tag.
                 key="Al0VE_jsmagxk4LFghXGlK5JSHfC0tk-eHRubZv_eMYm6wzgQaStYks8g-Wcgk3"
                 style="road" culture="en-US"/>
Right now, the overview component looks for both style and culture, hence it shows blank in your case. I would put in a fix for this.
--Sarthak Datt
ESRI Flex Team
Scott,
   I came up this the same thing as Sarthak. My fix was to change the OverviewMapComponent.mxml's bing case to the below.
case "bing":
         var veTiledLayer:VETiledLayer = new VETiledLayer();
         veTiledLayer.id         = label;
         veTiledLayer.key        = bingMapKey;
         veTiledLayer.visible    = visible;
         veTiledLayer.alpha      = alpha;
         veTiledLayer.mapStyle = style || "aerial";
         veTiledLayer.culture = culture || "en-US";
         ovMap.addLayer(veTiledLayer);
                                    break;
ScottBeaumont
Thanks a lot for the timely help.  I've made the change and things are working nicely.
KirstynAlex
Rscheitlin, where exactly do you put that code to make the bing map show up in the overview widget?
