New featurelayer feature not showing up automatically
1564
09-27-2012 05:54 AM
TylerWaring
Greetings Everyone,
I am editing a feature layer using the applyEdits and refresh methods like so:
editFeatureLayer.applyEdits([ lastDrawnGraphic ], null, null);
editFeatureLayer.refresh();
The new feature gets recorded in the database but does not show up in the map automatically. To get the new feature to show up I have to manually pan or zoom in a little.
How do I get the new feature to display automatically?
Thanks, Tyler
TylerWaring
Greetings Everyone,
I ended up creating a MapPoint and setting it's x and y properties equal to the slightly adjusted center of the map's extent using the following chunk of code:
var centerAt:MapPoint = new MapPoint;
centerAt.x = map.extent.center.x;
centerAt.y = map.extent.center.y -0.1;//slight adjustment
Following that, I reset the map's centerpoint to the slightly adjusted centerpoint with the following line of code.
map.centerAt(centerAt);
By readjusting the maps centerpoint my featuerLayer is forced to redraw and my new feature auto-magically appears.
While this works fine for my purposes, I can't help feeling like there is a better way.
Any suggestions will be greatly appreciated.
Thanks, Tyler
IvanBespalov
Try to set FeatureLayer.disableClientCaching = true.
Also, search this forum for 'disableClientCaching':
[ATTACH=CONFIG]18062[/ATTACH]
TylerWaring
I just checked my client caching and I already have it disabled. Hmmm...
Thanks, Tyler
SarthakDatt
Hey Tyler,
I think you are calling layer.refresh() too soon. You can listen for the 'edits complete' event to fire on the feature layer and then call refresh()
Something like:
editFeatureLayer.addEventListener(FeatureLayerEvent.EDITS_COMPLETE, editFeatureLayer_editsCompleteHandler);
private function editFeatureLayer_editsCompleteHandler(event:FeatureLayerEvent):void
      // You can also check if the edit was a success
Hope that helps.
