Navigate through all the features.
1421
5
08-24-2010 04:21 AM
shafitrumboo
In MY SFV, one widget is loaded at application startup (preloaded) . In the init methond of widget I want to navigate through all features of a layer that is added to map as featurelayer
I am able to  get the layer and also able to cast Layer into FeatureLayer.
But featurelay.featureCollection is null.
here is the code
var featurelayer:FeatureLayer;
for each (var layer:Layer in map.layers)
if( layer is FeatureLayer)
layer.refresh();
var featurelay:FeatureLayer = FeatureLayer(layer);
for each (var gra:Graphic in featurelay.featureCollection.featureSet.features)
gra.addEventListener(MouseEvent.MOUSE_OVER, rollOverGraphic);
gra.addEventListener(MouseEvent.ROLL_OUT, rollOutGraphic);
DasaPaddock
The features can be found in the inherited graphicProvider property.
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/FeatureLayer.html#graphicProvider
The featureCollection is used when you want to initialize the FeatureLayer with features from outside of ArcGIS Server like in this sample:
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=TemporalRenderer_FeatureCollection
BjornSvensson
Esri Alum
FYI: the API Reference for FeatureLayer and FeatureCollection has been updated today to better explain feature collections.  Hopefully the new information will be helpful:
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/supportClasses/FeatureCollection.ht...
shafitrumboo
But still featurelay.graphicProvider doesn't contain any Item. It's length is zero
Please help
DasaPaddock
You may be looking the the graphicProvider before the FeatureLayer has fetched the features from the server. To test this, don't preload the widget and instead open the widget after you see the features in the layer on the map.
DasaPaddock
Another option is to just listen for the inherited graphicAdd event and then add your mouse listeners there.
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/GraphicsLayer.html#event:graphicAdd
