NationalGridGeographic blocking Tooltip and popUp Info window text
559
04-11-2011 09:08 AM
DavidLancaster1
I extracted the NationalGridGeographic widget to use in application that is not using widgets.  When I import the application it works beautifulty, except the text for the tool tips in the main application and the text in the popUp window in my Identify component are no longer visible. When I "code out" or remove the NationalGridGeographic component (tool) the text returns.  Is the a code in the script effecting the text visibility?
Attached is the extracted code:
