Modify fields displayed in results table - Locate Widget
825
01-26-2012 02:56 AM
AndyCowx1
I've looked through the configuration of the locate wiget xml and don't see a way to amend the fields that are displayed in the results table and the popup when an address is shown.
I need to add the "House Suffix" field to both those items, is this possible via configuration ? I'm using the compiled widget and I'm not a Flex Developer.
Andy
RobertScheitlin__GISP
Andy,
   The correct forum for you to post Flex Viewer/Widget questions is the Flex Viewer forum here:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
As far as the available configuration options for the LocateWidget they can be found here:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Locate_widget_tags/01m30000000r000000/...
But the short answer is no you can not without modifying the code.
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
